1979 Ford F-250 With a 462 MEL Engine
Today, 22:00
It's a 1979 F250 with a 462 MEL motor out of a 1968 Lincoln continental
Says: Matthew M Allaire (Owner)
The 430 was replaced by the 462 cu in (7.6 L) engine in 1966. Bore and stroke were entirely different at 4.38 111.3 mm × 97.3 mm (4.38 in × 3.83 in) and the 462 MEL engine produced 340 hp (254 kW) and as much as 485 lb⋅ft (658 N⋅m) of torque. This engine was fitted with hydraulic lifters and a four-barrel Carter AFB carburetor. This large torquey engine was used only in Lincoln Continentals, from 1966 until mid-year in 1968 when it was replaced by the 385-series 460. Production ended after 1968. The production facilities in Lima were converted to produce the new Ford 385 engine family.
Here below are some pics that you may love to see!
Join Now - Ford News - Forum⬅
