1979 Ford F-250 7.6L 4x4
Today, 18:03
It's a 1979 F250 with a 462 MEL motor out of a 1968 Lincoln continental! The 430 was replaced by the 462 cu in (7.6 L) engine in 1966. Bore and stroke were entirely different at 4.38 111.3 mm × 97.3 mm (4.38 in × 3.83 in) and the 462 MEL engine produced 340 hp (254 kW) and as much as 485 lb⋅ft (658 N⋅m) of torque. This engine was fitted with hydraulic lifters and a four-barrel Carter AFB carburetor. This large torquey engine was used only in Lincoln Continentals, from 1966 until mid-year in 1968 when it was replaced by the 385-series 460. Production ended after 1968. The production facilities in Lima were converted to produce the new Ford 385 engine family.
Owner: Matthew M Allaire
