1953 F100 Built On F600 Chassis Diesel 4x4
Tomorrow, 06:40
1953 Ford F600 4x4 Cummins diesel 5-speed. All original sheet metal .Original farm truck.0 rust no sheet metal repair was needed on this Chassis off restoration.4x4 conversion Cummins diesel with 5 speed manual transmission .32k miles everything else is brand new. Original frame was used converted to hold the Cummins diesel set up and a front Dana 60 with a rear Dana 70.
Truck is clean show worthy and a head tuner. Runs great and drives great. Touch screen radio with bluetooth. All new custom interior. From TCI and mid fifties.4 inches of lift over the stock height. Running 235 55 22.5 semi wheels VDO billet gauge pod and gauges. Truck was stripped down to bare metal and painted original meadow green. Truck Has train horn and a E tone fire truck horn. Also has led light kit installed for the night car shows W/ remote. Disc brakes at all 4 corners. Wilwood 3 master brake and hydraulic cluth set up. Painless wiring17 gallon fuel cell 6an braided fuel lines and Russell fittings.
