1953 Ford F100 With a 5.0 Coyote 6R80 Father And Son Build
Tomorrow, 05:45
1953 Ford F100 Father and son build we have had for 14yrs Fresh frame off restomod restoration every nut and bolt. Frame boxed in certain areas for strength, every un used hole welded up, frame surfaced and painted satin black *Brand new zero mile crate Coyote/6R80 6 speed automatic from Ford Performance Doug's long tube headers, Pypes X, Borla XR1's with custom intake Custom 1 off motor mounts Custom transmission cross member Custom bead rolled and shaved firewall OEM fuel filler removed and steel filled Lokar floor shifter with sport mode Champion 3 row aluminum radiator TCI Mustang 2 and custom 4 Link with track bar and Viking adjustable coilovers Vintage Air power steering pump and a/c condensor Currie 9" with posi and 3.70 gears Custom build drive shaft Custom fuel cell relocated to the rear of the bed Wilwood slotted and drilled front disc brakes American Racing Torque Thrust 2's wrapped in BFG 245/60/15 up front and 275/60/15 in the rear 3" steel widened fenders Dakota Digital HDX digital gages Original bench seat customized with contoured foam and wrapped 100% in black leather to simulate a Mustang rear seat. Custom Coyote badging commissioned for the build for the engine cover, hood and wheel spinners.
Says: David Michael Sylican (Owner)
