1934 Ford Tudor Street Rod Pro Build
Today, 07:05
This 34' had a fortune invested in parts and a huge amount of total man hours of labor to build it (was very costly indeed). It has been temperature climate control stored since completion. The time and effort that went into the build is evident throughout in the quality of workmanship, parts and materials ready to go cruising with new modern components. I purchased this 34' Ford new from a Custom Rod Shop the entire new build was completed by Professionals.
1934 FORD TUDOR STREET ROD, FRESH PRO BUILD, ONLY 5,446 MILES SINCE COMPLETED, RARE DISCONTINUED DOWNS 3 1/2” CHOP BODY, PETE & JAKE CHASSIS, NEW FORD CRATE 302/300HP V-8 W/THUMPER CAM, FORD 9” W/COIL OVERS, PW, TILT, 4 ½” DROP SUPER BELL FRONT AXLE W/DISC BRAKES, ROCKET WHEELS W/HOOSIER RADIALS, C-4 AUTOMATIC, BLACK SATIN W/CUSTOM ACCENTS, CUSTOM BLACK BUCKET INTERIOR W/FULL BACK SEAT, CUSTOM DASH, MINT.
Ford Crate 302/300hp/4bbl with Thumper Cam, C-4 Auto Transmission, Ford 9” Rear with 3.55 cruising gears with Coilovers, Electronic Ignition, Side Exit look w/full dual exhaust under the car, Painless wiring with battery mounted right rear behind the seat, Ford Gas Tank. New mechanical systems have low only 5,500 gently driven miles since completion. It runs sounds amazing with simply an awesome running and driving Street Rod.
