1978 Ford Truck F-250 With a 460 Engine
Today, 08:55
1979 460 Block & 1970 DOVE closed chamber heads w/ roller rockers & comp.cam 9.6;1 Compression runs on 91 Octane, Quick fuel 650 cfm carb. MSD Ignition 6A ignition box w/MSD distributor, Ignition wires & coil, Powermaster high torque starter & Optima battery L&l Nickel coated headers. 3" flowmaster DBX mufflers w/ 3.5 ST. steel tipps Champion 4 Core aluminum Radiator, 16" Darele electric fan w/ custom stainless steel shroud. CVF Billet Aluminum serpentine belt system 8 rib belt w/ GM power steering pump w/ remote Billet aluminum reservoir. Rebuilt 1990 ZF 5 Speed transmission w/ hydraulic clutch w/ custom crossmember w/205 Neutral and 2WD, Has Lockout hubs original cast iron Transfer case W/ 4Low & 4 High.
Dana 60 in rear & Dana 44 in front, Bilstein 51 00 series shocks w/ custom front shock towers Skyjacker 4" springs on rear and air bags on front used as a spring assist for a firm ride, 35x'12.50x16 M tires on Mickey Thompson wheels, Skyjacker steering stabilizer shock kit After market Nostalgic A/C & heater 1 34A freon. Has Factory cruise control, tilt wheel and Manual 4 wheel disc brakes, All new custom brass/nickel brake & fuel lines Lariat Door panels and headliner & dash trim, 4 F-250 re-upholstered seat w/ 3 point seat belts Sandblasted frame & applied Bedliner, Cab was tore down sandblasted sealed , No Rust in this truck not even over the wheel wells or quarters Applied bedliner from the firewall underneath all the way to the bumper for long rust free life. Has 34 Gallon rear steel fuel tank & factory Plastic 20 gal. front fuel tank Has factory dentside wide trim & narrow race track trim 2016 Cadillac Black paint w/ a GM silver 2 Tone Paint job.
