1976 Ford F-250 Highboy With a 6-inch Lift
Tomorrow, 02:47
Tyler Wall (Owner) says: This is a 1976 Ford F-250 high boy with a 6 inch lift and 35 inch tires, I put a 12 valve Cummins with a 5 speed transmission, dual dual disk clutch and an np205 transfer case. Dana 60 front with crossover steering, Dana 70 rear ended with disk brake conversion 3.55 gears. Engine mods, advanced timing 20 degrees, fuel pin, gov spring, air dog fuel system, s362 turbo and 100 horse injectors. Get around 20 mpg, great cruising truck!
Owner:
