FORD BRONCO 4X4! FORD 351CI V8 4X4
Tomorrow, 06:41
Check out this amazing 1979 Ford Bronco 4X4. This Bronco is in pristine condition and it's sporting a glossy Black Paint finish, Free Wheeling Decal Stripe Package, Black Fiberglass Roof, Red Interior, 4'' Rough Country Lift, Trailer Hitch, 15'' Polished Aluminum Wheels, 35'' BFGoodrich All-Terrain T/A Tires, Retractable Tailgate Window, along with Polished Components all around. This Bronco has been very well kept over the years and it shows throughout. Under the hood sits a Numbers Matching Ford 351 Modified V8 Engine with a Motorcraft 2-Barrel Carburetor sitting on top! Power is put to the pavement through a Numbers Matching Ford C6 3-Speed Automatic Transmission, New Process 205 Transfer Case, Ford 9'' Rear Differential with 3.50 Gears, and a Dana 44 Front Differential with 3.50 Gears and Manual Locking Hubs! This Bronco drives amazing and it's ready for your next adventure thanks to the equipped 4X4, Air Conditioning, Power Brakes (front disc), and Power Steering. Photo By vanguardmotorsales
The interior of this '79 Bronco is absolutely beautiful and it's in great condition! Take a look inside to see this Ford sporting Split-Bench Seating up front, Rear Bench Seating, Seat Belts all around, Red Vinyl Upholstery throughout, Black Floor Liner, 3-Point Steering Wheel, Transmission Column Shifter, Transfer Case Floor Shifter, beautiful Dashboard and Gauges, AM/FM Radio, along with a Spare Tire that's mounted in the back! The underside of this Bronco looks amazing like the rest of the truck! Take a look underneath to the the beautiful condition of the Frame, Floors, Rocker Panels, Fuel Tank, Fuel and Brake Lines, Brakes all around, Front and Rear Differentials, New Process Transfer Case, C6 Transmission, Engine Oil Pan, Steering Components, Coil Spring Front Suspension, Leaf Spring Rear Suspension, along with the New Cat-Back Exhaust that's fitted with a Flowmaster Muffler!
This 1979 Ford Bronco 4X4 is an amazing truck and it's ready to be driven on or off the road! Traveling along with this Bronco is a copy of the Marti Report, Owners Guide, along with a Factory Electric Brake Harness. The Ford Bronco is quite a collectible vehicle and this one won't last long! Call us today before it's gone!
Mark Dudley
Is this Bronco still available?
Tomorrow, 06:41
