1978 Ford F-350 Crew Cab Long Bed 4x4
Today, 20:34
Pretty hard running 460 with a C6 tranny and a 205 transfer case. 411 gears with 37/13. 50/17 Toyo mud terrains. New 50 series dual flowmaster exhaust. This truck is pretty well a new truck. Has no rust or patch panels anywhere and nice PPG base coat with 4 coats of clear cut and buffed to a high shine paint job inside and out including ghost flames in purple pearl on the front. New interior. CB. CD player with amp. subs with tweeters in the top corners of the doors. New wheels and tires with 20 miles on them. new drive train from front to rear including completely rebuilt Dana 60s front and rear. and yes its a 1978 high pinion open knuckle king pin front axle. All new brakes. drums. calipers. E brake cables. nbsp; bearings. seals. If it could be replaced it was. New fuel tanks. sending units for both. 19 gallon in the front and 38 gallon in the rear. All new shocks. front and rear springs. shackles. sway bar bushings. brake lines and U joints front and rear were replaced also. Frame rails were also stripped to bare metal and repainted. Has a lit Lund visor and bushwacker flares which are both very hard to find. also has a power sliding rear window.. I have a folder full of receipts from start to finish on this build. If you were to build this truck it would cost over 40K. Thanks. Jeremy
