1977 Ford F150 4x4 4 Speed Custom
Today, 23:30
Highboy ford Well the old 1977 ford I’ve been fixing up is almost finished, about 3 months of work but it turned out reasonably well I think, a huge change from when I started it! 1977 F-150 4x4 4speed custom, 351 M 4” rough country lift Mickey Thompson 17” wheels and 35x12.50 general grabber red line tires. I undercoated every panel on the entire truck, the frame had a factory coating on it, I loomed every wire on the entire pickup including the dash, the only thing not working yet is the speedometer, I’m having problems finding the plastic gear for the transfer case, I used kilomate I the floorboards inside the doors and roof, then an extra sound deadening in the roof, every rubber bushing and seal has been replaced. it, I loomed every wire on the entire pickup including the dash, the only thing not working yet is the speedometer, I’m having problems finding the plastic gear for the transfer case, I used kilomate I the floorboards inside the doors and roof, then an extra sound deadening in the roof, every rubber bushing and seal has been replaced.
