1976 Ford F350 Powerstroke Turbo Diesel Lifted
Tomorrow, 06:42
This is a one of a kind truck! This started out as a 1999 Ford Super Duty F350 powered by the 7. 3L powerstroke intercooled turbo diesel engine. backed by the 6 speed manual transmission. The body of the truck is a 1977 build date. and it's titled as a 1976. The entire running gear. steering. suspension. axles. brakes are all 1999 Ford. The frame is a super duty frame. The dash has been made to fit inside the cab. and all gauges work. It has a power front bench seat that works as well. The body has no rust. and the paint is what I call a 10 footer. It looks good until you get up close and you'll see some small runs and orange peel in it. No bondo that I could find. The truck starts up. runs and drives like a 1999. The things it needs are
1. Drivers side window regulator is no good
2. The heater works but doesn't blow very strong.
3. a/c is inop/missing
4. tires are thin
5. Hood latch is a pain to release
6. Drivers door handle needs adjusting. it opens fine but it catches at the very top of lifting it up.Source car-from-uk
