1961 Ford F-250 Crew Cab Custom 4x4
Today, 08:42
1961 Ford F250 crew cab.Complete ground up restoration.This truck started off a custom coach works build for the rail road in 1961.The frame was later sourced out for a 1979 ford f-250 super cab.drives like a dream with plenty of power from a rebuilt ford 428 motor.Truck has power steering and power disc brakes at front, drum at rear.Front end and rear end have been completely rebuilt has posi traction at both differentials.Skid plates were installed at front and rear axles .Transmission c-6 was professionallyrebuilt using all the most heavy duty parts available.Has tilt steering column and retro style blue tooth stereo with four speakers .Bumpers were custom made for front and rear 8000 lb Ramsey commercial grade winch sits at front of the truck.Vintage air heating was installed with damper and heat control.Upholstery work speaks for itself absolutely gorgeous new hand cranks door handles and mirrors have been installed.The bed has polished aluminum diamond plating on all sides the floor has galvanized sheet metal top and bottom sandwiched between 3/4 ply wood with a 1" rubber mat.Seat belts have been installed for six people.Weatherstripping has been replaced through out the entire truck .There are four polished custom slotted mags sitting on 37" good year wrangler tires .Truck is painted with base coat clear coat with Wimbledon white and blue. this truck was completed five years ago and has approximately 10,000 miles since restoration and has always been garaged .
