1960 Ford F-100 Original Patina Paint
Tomorrow, 03:30
1960 Ford F-100 Additional Info:
1960 Ford F100
Ford 390
Ford C6 transmission with Lokar 23 inch shifter
Ford 9 inch rear end
New Bench seat and carpet kit
Custom Wood Bed
sids 3 inch drop axle
disc brakes
steering dampener
all new tierods and king pins
whitewalls
rebuilt Holley 2 barrel
new Champion Radiator
New distributor
Pertronix electronic ignition
New Battery
New Spark plugs and Wires
rear is c notched with all new shocks and boxed frame
Front frame is notched and boxed from previous axle flip and allows truck to be lowered up front more
head lights and brake lights work
gas gauge works
New Alternator
new exhaust with glass packs
rebuilt heads from K and R engine less than 1 month ago
new custom cut driveshaft and u joints
new brake booster and all new steel brake lines
all new fuel lines
new fuel pump
new oil pump
New starter
New starter solenoid
New Coil
has rust in the usual places and the truck is solid
clean pink in hand
literally replaced every part that could cause truck to not be reliable.
I have a frontwindshield no cracksI have not installed yet. no side glass but that can be arranged. its flat glass and easy to get made or order pre cut
Tail gate is rusted and tack welded in place
any questions please ask
